Problem I / O mismatch detected, BL460c G6 Blade c7000 (3389 Views)
Reply
Highlighted
Super Advisor
Message 1 of 3 (3,389 Views)
Accepted Solution
Hi all, I have a problem in a c7000 blade chassis HP.
The configuration of the interface modules is:
Bay1-HP VC-Enet Module 1/10Gb
Bay2 - HP VC-Enet Module 1/10Gb
Bay3 - Brocade 4/12 SAN Switch for HP c
Bay4 - Brocade 4/12 SAN Switch for HP c
OnBoard Version: Firmware Version: 3.70
When I connect a blade of this type:
Model: ProLiant BL460c G6
Manufacturer: HP
Part Number: 507780-B21
Mezz 1
Model: QLogic iSCSI adapter QMH4062
Manufacturer: QLogic
Part Number: 488074-B21
Product View: 0A
When the QLogic FC card is plugged in Position 1, I get this error:
1
I / O mismatch detected. Plesase see port mapping information
2
thank you very much
Honored Contributor
Message 2 of 3 (3,381 Views)
Re: Problem I / O mismatch detected, BL460c G6 Blade c7000
[ Edited ]
hi,
It looks that You are trying to connect a ethernet mezzanine card to a fibre channel VC module.
QMH4062 is a ethernet mezzanine card.
Thanks
regards,
How to Say Thank You? Just click the KUDOS Star!
Super Advisor
Message 3 of 3 (3,372 Views)
PGTRI Hello, thanks for answering, you're right, it was a mistake of mine, I did not watch the card.
thank you very much
The opinions expressed above are the personal opinions of the authors, not of HP. By using this site, you accept the Terms of Use and Rules of Participation.
