UPS r1500 g3 Battery Capacity problem (1113 Views)
Reply
Occasional Visitor
Message 1 of 7 (1,113 Views)
Hello all!
I'm desperate,  because I don't know how to solve this problem. We have brand new UPS R1500 g3.
UPS works normally, everything is "green". But when I go to to HP Power Protector, there is a status of battery capacity always on 82%. We have replaced 2 UPS till now, but every time status of battery capacity is on 82%.
Firmware version is the latest : 1.08
DIP switches are positioned correctly.
I don't know what to do. Can you give me some advice?
Please see attached picture.
Thank you!!!
Janez
Occasional Visitor
Message 2 of 7 (1,112 Views)
Re: UPS r1500 g3 Battery Capacity problem
Sorry, I forgot to attach a picture.
Acclaimed Contributor
Message 3 of 7 (1,096 Views)
Did you wait long enough?
From manual:
Charge the batteries for at least 24 hours before supplying backup power to
devices. The batteries charge to:
- 90% of their capacity within 4 hours
- 100% of their capacity within 24 hours
Hope this helps!
Regards
Torsten.
__________________________________________________
There are only 10 types of people in the world -
those who understand binary, and those who don't.
No support by private messages. Please ask the forum!
If you feel this was helpful please click the KUDOS! thumb below!
Occasional Visitor
Message 4 of 7 (1,090 Views)
[ Edited ]
Hi Torsten!
Thank you for your  quick response.
Yes I did charge enough. UPS has been charging for about 14 days. And it is still on 82 %.
I though that something was wrong with UPS generally, so we ordered completelly new one, under warranty.
With new UPS situation is the same.
I took UPS to another location, pluged it in to a different "electricity"- same situation.
Please help.
Janez
Occasional Contributor
Message 5 of 7 (964 Views)
sorry I do not have solution , I have same trouble . Two UPC after 2 week in the 78 and 80 % . Have you solution ? thanx
Occasional Visitor
Message 6 of 7 (745 Views)
I am having same issue.
Battery has been stuck at between 80%-81% on utility power charging for more then a month.
In addition it has begun alarming indicating a battery test failure.
Any suggestions? or solutions?
Occasional Visitor
Message 7 of 7 (326 Views)
We're having the same issue.
Just swapped for another identical UPS (under warranty) - UPS battery capacity has been around 86% mark since installation yesterday.
The older UPS was at 82%.
The opinions expressed above are the personal opinions of the authors, not of HP. By using this site, you accept the Terms of Use and Rules of Participation.
