Need help.Compaq 6300 Pro.Power supply replacement.Very important. (337 Views)
Reply
Occasional Visitor
Message 1 of 3 (337 Views)
Hello.My power supply(PS) has started to noise too strong recently.Sometimes PC has  blacked out and then reloaded.(At this time  power supply fan  rotating like turbojet).So I need to buy new one.But standard HP PS has only 3 wires and i afraid that i can buy wrong power supply.Can you explain me,what PS i need to buy?(20+4 pin and etc)
Sorry for my English.
Frequent Visitor
Message 2 of 3 (285 Views)
Re: Need help.Compaq 6300 Pro.Power supply replacement.Very important.
The part number should be on top of the power supply, in really small letters.
For SFF model the spare part number is either 613762-001 (90%) or 613763-001 (standard).
For MT model the spare part number is either 613764-001 (90%) or 613765-001 (standard).
Occasional Advisor
Message 3 of 3 (192 Views)
Has anyone found a power supply tester that supports the small 6 pin system board connection? The 6 and 4 pin Molex are standard but the 6 pin small white one has no adapter or tester I can find!
The opinions expressed above are the personal opinions of the authors, not of HP. By using this site, you accept the Terms of Use and Rules of Participation.
